Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W690 LCD screen Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W690 LCD screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the battery door.
  2. Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 2, Bild 1 von 1
    • Open the battery lock by pushing the lid towards the inside and lifting.
  3. Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery.
  4. Sony Cyber-shot DSC-W690 LCD screen Replacement, Front and Back Case: Schritt 4, Bild 1 von 1
    • Remove the wrist strap from the camera.
  5. Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 5, Bild 2 von 2
    • Remove all six 3 mm screws from the outside of the camera using a Phillips #00 screwdriver.
  6. Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 6, Bild 2 von 2
    • Carefully pry the case apart by pulling the front and back sides in opposite directions.
  7. Sony Cyber-shot DSC-W690 LCD screen Replacement, LCD screen: Schritt 7, Bild 1 von 1
    • Use spudger to delicately open wire contact.
  8. Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 8, Bild 1 von 1
    • Gently push the LCD screen out of back case.
  9. Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the button circuit board.
  10. Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 10, Bild 1 von 2 Sony Cyber-shot DSC-W690 LCD screen Replacement: Schritt 10, Bild 2 von 2
    • Use spudger to pry apart the LCD screen from the support bracket.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Will Norris
620 Reputation
4 Anleitungen geschrieben
Clemson, Team 15-6, Shirley Winter 2015 Mitglied von Clemson, Team 15-6, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G6
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 16
Insgesamt: 886
