Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the Button Board:
  • The Button Board is an integral part of the device and any improper handling can cause issues in other parts of the camera.
  • Be cautious when removing ribbon wires.
  • Be sure to keep track of all pieces that are taken apart.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the five 4.0 mm Phillips #000 screws on the back panel. Remove the five 4.0 mm Phillips #000 screws on the back panel. Remove the five 4.0 mm Phillips #000 screws on the back panel.
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Using the Spudger, remove the back panel from the device. The loose piece circled in the picture will most likely fall off the camera housing.
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  4. Remove the two 2.15mm Phillips #000 screws from the circuit board. Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board. Ribbon wires can easily be damaged.
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Thomas Campo
746 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 17-5, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Mitglieder
5 Anleitungen geschrieben
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Antwort
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Antwort
follow the step the button are unstuck but the camera display still stock on language setting
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 23
Insgesamt: 1,172
