Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the LCD Screen:
  • The LCD Screen is an integral part of the device and any improper handling can cause issues in other parts of the camera.
  • Be cautious when removing ribbon wires.
  • Be sure to keep track of all pieces that are taken apart.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the five 4.0 mm Phillips #000 screws on the back panel. Remove the five 4.0 mm Phillips #000 screws on the back panel. Remove the five 4.0 mm Phillips #000 screws on the back panel.
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Using the Spudger, remove the back panel from the device. The loose piece circled in the picture will most likely fall off the camera housing.
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Remove the two 2.15mm Phillips #000 screws from the circuit board. Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board. Ribbon wires can easily be damaged.
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  5. Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  6. Lift the back panel and separate the LCD Screen by prying it up.
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  7. Gently pull on the ribbon wire disconnecting from the ZIF connector  (connecting the LCD screen to the motherboard) with the tweezers. Ribbon wires can be easily damaged.
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Thomas Campo
764 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 17-5, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 16
Insgesamt: 1,324
