Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W800 Lens Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: Schritt 1, Bild 3 von 3
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 2, Bild 2 von 2
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 Lens Replacement, LCD Screen: Schritt 4, Bild 1 von 1
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 5, Bild 1 von 1
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 6, Bild 2 von 2
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
  7. Sony Cyber-shot DSC-W800 Lens Replacement, Lens: Schritt 7, Bild 1 von 2 Sony Cyber-shot DSC-W800 Lens Replacement, Lens: Schritt 7, Bild 2 von 2
    • With plastic opening tool, gently pry loose the front panel.
    • Separate front panel from the camera housing.
  8. Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 8, Bild 1 von 3 Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 8, Bild 2 von 3 Sony Cyber-shot DSC-W800 Lens Replacement: Schritt 8, Bild 3 von 3
    • Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
    • Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
    • Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
    • Be careful not to damage either of the ribbon wires.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Thomas Campo
851 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 17-5, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 85
Insgesamt: 5,672
