Einleitung
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the Motherboard:
- The Motherboard is an integral part of the device and any improper handling can cause issues in other parts of the camera.
- Be cautious when removing ribbon wires.
- Be sure to keep track of all pieces that are taken apart.
Was du brauchst
Using the Spudger, remove the back panel from the device.
The loose piece circled in the picture will most likely fall off the camera housing.
Remove the two 2.15mm Phillips #000 screws from the circuit board.
Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
Lift the back panel and separate the LCD Screen by prying it up.
Remove the back panel.
Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
With plastic opening tool, gently pry loose the front panel.
Separate front panel from the camera housing.
Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
Remove the single 3.75 mm Phillips #000 screw from the base of the motherboard.
Remove the two 3.5 mm Phillips #000 screws from the secondary board that is attached to the flash bulb.
Use the tweezers. Move the thick red cable, attached to the secondary board, outside of its place in the camera housing.
Gently pull on the red/black wire in order to free the photo lens cylinder from the housing.
Remove the secondary board from its position and move it upward, out of the way.
Using the tweezers, pull the indicator bulb out , freeing it from its position on the housing.
Thread the indicator bulb under and through the secondary boards position.
Using the tweezers, remove the black/red speaker wire from camera housing.
Pry loose and remove the speaker from the camera housing.
Pull up on the bottom-half of the motherboard, slightly removing it from its position in the housing.
With enough force, pull up on the top right of the motherboard, pulling it entirely from its position in the housing.
2 weitere Personen haben diese Anleitung absolviert.
