Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: Schritt 2, Bild 1 von 1
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: Schritt 3, Bild 3 von 3
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to gently release the two indicated tabs.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Matthew
583 Reputation
4 Anleitungen geschrieben
Michigan Tech, Team 1-9, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-9, Lauer Spring 2015
MTU-LAUER-S15S1G9
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Where I can buy the Outer Casing..¿??
ING CHARLY - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 948
