Einleitung
If the flash assembly is broken or not working properly, follow this guide to replace it.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide the gray switch from lock to open position.
    • Slide the gray switch from lock to open position.
  2. Pull down on the blue tab to release the battery. Pull down on the blue tab to release the battery.
    • Pull down on the blue tab to release the battery.
  3. Use a PH00 screwdriver to remove the  five 3.5 mm screws. Use a PH00 screwdriver to remove the two 2.5 mm screws. Use a PH00 screwdriver to remove the two 2.5 mm screws.
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Pry apart the case gently using a plastic opening tool. Pry apart the case gently using a plastic opening tool.
    • Pry apart the case gently using a plastic opening tool.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Pry back the panel to the right of the screen using a plastic opening tool.
    • Pry back the panel to the right of the screen using a plastic opening tool.
  7. Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  8. Pull out the ZIF cable from the motherboard.
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZF cable, pull it straight out to avoid damaging the cable.
  9. Pull the capacitor out of the shell.
    • Pull the capacitor out of the shell.
    • Be careful not to shock yourself on the capacitor(metal components on the top)
  10. Unpin the flash assembly.
    • Unpin the flash assembly.
  11. Lift flash component toward you and gently pull the ZIF cable up and away from the camera.
    • Lift flash component toward you and gently pull the ZIF cable up and away from the camera.
Abschluss
Kate Glazer
579 Reputation
5 Anleitungen geschrieben
IUPUI, Team S6-G3, Baechle Spring 2018 Mitglied von IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 110
