Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-WX220 Lens Assembly Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 2, Bild 2 von 2
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: Schritt 3, Bild 3 von 3
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 4, Bild 2 von 2
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Lens Assembly: Schritt 5, Bild 1 von 1
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 6, Bild 1 von 1
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 7, Bild 1 von 1
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZIF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 8, Bild 2 von 2
    • Unpin the ZIF cable by lifting the cable towards the top of the camera while pulling up towards yourself.
    • Pull the ZIF cable out.
  9. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: Schritt 9, Bild 1 von 1
    • Lift the lens out of the case.
    • Pull out the ZIF cable.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Kate Glazer
621 Reputation
5 Anleitungen geschrieben
IUPUI, Team S6-G3, Baechle Spring 2018 Mitglied von IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 44
Insgesamt: 1,193
