Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-WX350 Motherboard Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-WX350 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-WX350 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-WX350 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove 6 Phillips 4mm screws from the bottom and sides of the device.
    • Remove the 1 Phillips 4mm screw from under the battery cover.
  2. Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool between the back cover and the bottom plate. Gently pry the cover off.
  3. Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use your fingers to slide out the controller wheel board.
  4. Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  5. Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Once the LCD is off use the J00 screwdriver to take out the two 4mm silver screws. Once the screws are taken out pull off the piece with your fingers.
  6. Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the three ZIFs connected to the motherboard. The top is found under a piece of tape.
  7. Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 7, Bild 1 von 2 Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Remove the lens assembly and motherboard from the front of the case.
    • The lens assembly should separate when removing the front.
  8. Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 8, Bild 1 von 3 Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 8, Bild 2 von 3 Sony Cyber-shot DSC-WX350 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • On the backside of the motherboard, a silver clip is holding the motherboard to the plastic shell. Insert the plastic opening tool under the clip and pry gently until it releases.
Abschluss
Ryan Speitel
101 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G1, Wilson Summer 2017 Mitglied von IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
4 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
Schön erklärt ich freu mich das es sowas gibt ich würde mich noch mehr freuen, wenn es zu der zoom einheit eine Reperatur anleitung giebt. Meine ist jetzt nun schon zum zweiten mal kaputt anscheinend hat diese kamara Probleme mit Strand/Sand Salzwasser in der Luft bezogen auf das Objektiv .
Hannet Jacob - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 1,609
