Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-WX80 Battery Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Battery Replacement: Schritt 2, Bild 1 von 3 Sony Cyber-shot DSC-WX80 Battery Replacement: Schritt 2, Bild 2 von 3 Sony Cyber-shot DSC-WX80 Battery Replacement: Schritt 2, Bild 3 von 3
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Battery Replacement: Schritt 3, Bild 1 von 1
    • Access where the replacement battery will go indicated by the red square in the photo to your left
    • Now insert your new replacement battery
Abschluss
2 Kommentare
Why did you not just open the bottom battery door instead of pulling the camera apart?
Kat - Antwort
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
Chung-Suh Ku - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 1,038
