Einleitung
Make sure you have the necessary tools in order to complete the front cover replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
Was du brauchst
Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
Pry the front cover off gently. Use a plastic opening tool if available.
Now that you have removed the front cover you can replace it!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
