Einleitung
Make sure you have the necessary tools in order to complete the lens replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
Was du brauchst
Begin by removing all six #00 40mm by 10mm black screws holding the outer frame together with the Phillips #00 Precision Screwdriver.
Pry the front cover off gently. Use a plastic opening tool if available.
Now pry the back cover off gently, using a plastic opening tool if available.
Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial. Reference the first image.
Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side. Reference the second image.
Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device. Reference the first image.
Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon. Reference the second image.
Your LCD screen is now removed and you can replace it!
After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
