Einleitung
This guide will show how to replace the camera lens on a Sony Cyber-Shot DSC-W80.
Was du brauchst
Push the purple latch with your thumb to unlock the battery.
Pull the battery out.
Remove the middle panel on the side of the device.
Slowly pry the camera apart at its seem.
Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
Once disconnected, use your fingers to lift lens out of the frame.
Eine weitere Person hat diese Anleitung absolviert.
