Zum Hauptinhalt wechseln
Sony Cybershot DSC-W830 Motherboard Replacement
Was du brauchst
  1. Sony Cybershot DSC-W830 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Cybershot DSC-W830 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W830 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: Schritt 3, Bild 1 von 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: Schritt 3, Bild 2 von 3 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: Schritt 3, Bild 3 von 3
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W830 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W830 Motherboard Replacement: Schritt 5, Bild 1 von 2 Sony Cybershot DSC-W830 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W830 Motherboard Replacement, Lens: Schritt 6, Bild 1 von 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: Schritt 6, Bild 2 von 3 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: Schritt 6, Bild 3 von 3
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
  7. Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: Schritt 7, Bild 1 von 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: Schritt 7, Bild 2 von 3 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: Schritt 7, Bild 3 von 3
    • Lift the power button board up off of the daughterboard.
  8. Sony Cybershot DSC-W830 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  9. Sony Cybershot DSC-W830 Motherboard Replacement: Schritt 9, Bild 1 von 2 Sony Cybershot DSC-W830 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
  10. Sony Cybershot DSC-W830 Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Remove the two remaining ribbon cables.
    • Pull the motherboard from the camera.
Abschluss
Saiman Sigdel
167 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 40
Insgesamt: 692
