Einleitung
The following is a guide to disassemble the camera into two primary halves. It will serve as prerequisite guide to few a other guides hosted by this page.
Was du brauchst
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
Once all the screws are removed you can safely pry open the camera case using a spudger.
