Zum Hauptinhalt wechseln
Sony DCR-DVD 108 LCD Screen Replacement
Was du brauchst
  1. Sony DCR-DVD 108 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
  2. Sony DCR-DVD 108 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
  3. Sony DCR-DVD 108 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
  4. Sony DCR-DVD 108 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Slowly pry apart the covers using a plastic spudger.
    • Be sure to disconnect the ZIF connector holding the ribbon cable in place. To do this, use a spudger to flip the black tab up, and pull the cable out with tweezers.
    • This photo shows a torn ribbon cable. Be sure to disconnect the ribbon cable before fully removing the LCD cover, to avoid damage to the device.
Abschluss
USF Tampa, Team 7-6, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 21
Insgesamt: 657
