Zum Hauptinhalt wechseln
Sony DCR-DVD 108 Motherboard Replacement
Was du brauchst
  1. Sony DCR-DVD 108 Motherboard Replacement, Sony DCR-DVD 108 Case Disassembly: Schritt 1, Bild 1 von 1
    • Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
  2. Sony DCR-DVD 108 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the 5mm #0 Phillips screws on the underside of the LCD tuck-a-way.
  3. Sony DCR-DVD 108 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the 2mm #0 Phillips screw behind the battery.
  4. Sony DCR-DVD 108 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
  5. Sony DCR-DVD 108 Motherboard Replacement: Schritt 5, Bild 1 von 2 Sony DCR-DVD 108 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Once all the screws are removed you can safely pry open the camera case using a spudger.
  6. Sony DCR-DVD 108 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 Sony DCR-DVD 108 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
    • Be careful not to bend the ribbon cables.
    • There is a hidden wire on the bottom of the board that should also be removed.
  7. Sony DCR-DVD 108 Motherboard Replacement: Schritt 7, Bild 1 von 3 Sony DCR-DVD 108 Motherboard Replacement: Schritt 7, Bild 2 von 3 Sony DCR-DVD 108 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove 3 brown copper screws. Each copper screw has a #0 Phillips head and is 2.8mm in length.
  8. Sony DCR-DVD 108 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Lift the motherboard up from the outside edges to remove.
Abschluss
In order to reassemble your device, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 7-6, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 578
