Zum Hauptinhalt wechseln
Sony DSC-RX100MA Back Cover Replacement
Was du brauchst
  1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Back Cover Replacement: Schritt 2, Bild 1 von 3 Sony DSC-RX100MA Back Cover Replacement: Schritt 2, Bild 2 von 3 Sony DSC-RX100MA Back Cover Replacement: Schritt 2, Bild 3 von 3
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Back Cover Replacement: Schritt 3, Bild 1 von 3 Sony DSC-RX100MA Back Cover Replacement: Schritt 3, Bild 2 von 3 Sony DSC-RX100MA Back Cover Replacement: Schritt 3, Bild 3 von 3
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Back Cover Replacement: Schritt 4, Bild 1 von 2 Sony DSC-RX100MA Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Back Cover Replacement: Schritt 5, Bild 1 von 3 Sony DSC-RX100MA Back Cover Replacement: Schritt 5, Bild 2 von 3 Sony DSC-RX100MA Back Cover Replacement: Schritt 5, Bild 3 von 3
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Back Cover Replacement: Schritt 6, Bild 1 von 2 Sony DSC-RX100MA Back Cover Replacement: Schritt 6, Bild 2 von 2
    • Remove the back cover
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
KC Egger
294 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 21-1, Maness Winter 2017 Mitglied von Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Mitglieder
10 Anleitungen geschrieben
0Leitfaden Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 52
Insgesamt: 3,401
