Einleitung
Need to clean the inside of the camera? Start by taking off the back cover.
Was du brauchst
Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
Remove the marked 2.5 mm screws with the screwdriver
Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
Eine weitere Person hat diese Anleitung absolviert.
