Was du brauchst
Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
Remove the marked 2.5 mm screws with the screwdriver
Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
Move side panel to get access to screws
Remove two screws (black 2.5mm) with PH #0 screwdriver
Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
Using the Philips Screwdriver, remove the screw (black 3mm) located on the copper casing.
Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
Remove casing.
Using the Philips screwdriver, remove the three (silver 3mm) screws
Remove the screw (silver 2mm) from the upper right hand corner
Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
Eine weitere Person hat diese Anleitung absolviert.
