Einleitung
Batteries wear down overtime. If your device’s battery has a short life span, cannot hold a charge, or is damaged, replacing the device’s battery is a good solution. This guide will help you to remove the battery from the Sony DSC-RX10M3.
Was du brauchst
Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
Fast fertig!
Abschluss
