Zum Hauptinhalt wechseln
Sony DVP-FX730 Cover Replacement
Was du brauchst
  1. Sony DVP-FX730 Cover Replacement, Cover: Schritt 1, Bild 1 von 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: Schritt 3, Bild 1 von 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
Abschluss
Cal Poly, Team 11-21, Maness Winter 2012 Mitglied von Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,453
