Zum Hauptinhalt wechseln
Sony DVP-FX730 Laser Replacement
Was du brauchst
  1. Sony DVP-FX730 Laser Replacement, Cover: Schritt 1, Bild 1 von 1
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Laser Replacement: Schritt 2, Bild 1 von 1
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Laser Replacement: Schritt 3, Bild 1 von 1
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Laser Replacement: Schritt 4, Bild 1 von 1
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Laser Replacement, Laser: Schritt 5, Bild 1 von 2 Sony DVP-FX730 Laser Replacement, Laser: Schritt 5, Bild 2 von 2
    • Remove the large connector.
    • Remove the small connector.
  6. Sony DVP-FX730 Laser Replacement: Schritt 6, Bild 1 von 1
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Sony DVP-FX730 Laser Replacement: Schritt 7, Bild 1 von 1
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Sony DVP-FX730 Laser Replacement: Schritt 8, Bild 1 von 2 Sony DVP-FX730 Laser Replacement: Schritt 8, Bild 2 von 2
    • Unlock the lock clip
  9. Sony DVP-FX730 Laser Replacement: Schritt 9, Bild 1 von 1
    • Remove the T6 screws with the T6 screwdriver.
  10. Sony DVP-FX730 Laser Replacement: Schritt 10, Bild 1 von 1
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Sony DVP-FX730 Laser Replacement: Schritt 11, Bild 1 von 2 Sony DVP-FX730 Laser Replacement: Schritt 11, Bild 2 von 2
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. Sony DVP-FX730 Laser Replacement: Schritt 12, Bild 1 von 1
    • The laser is now removed.
Abschluss
Cal Poly, Team 11-21, Maness Winter 2012 Mitglied von Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
where do I buy the lens?
mnmmacd - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 4,682
