Einleitung
If you need to replace an old or damaged motherboard, access the motherboard with this guide. The motherboard is a vital piece for the Sony DVD player, It runs all systems making sure everything is running properly and smoothly.
Was du brauchst
Use the Philips screwdriver to remove the screws located on the sides and the back.
Remove all cables that are connected to the motherboard by pulling upwards from the motherboard.
Use a Phillips screwdriver to remove all screws located in the 4 corners of the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
