Zum Hauptinhalt wechseln
Sony Dream Machine ICF-C180 Speaker Replacement
Was du brauchst
  1. Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: Schritt 1, Bild 2 von 3 Sony Dream Machine ICF-C180 Speaker Replacement, Speaker: Schritt 1, Bild 3 von 3
    • Detach the top of the plastic casing. Use a Phillips head screwdriver to unscrew the three bottom screws.
  2. Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 2, Bild 1 von 2 Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 2, Bild 2 von 2
    • Wedge a plastic opening tool between the face of the clock and the body.
    • Pry open the face of the clock away from the body.
  3. Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 3, Bild 1 von 2 Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 3, Bild 2 von 2
    • To open the top casing, pull it upward.
    • Be careful not to yank on the ribbon cable when pulling on the top casing.
  4. Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 4, Bild 1 von 2 Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 4, Bild 2 von 2
    • Pull upward on the blue and white ribbon cables to remove them. This will make it easier to remove the speaker.
  5. Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 5, Bild 1 von 2 Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Desolder the wires going to the speaker with a soldering iron.
  6. Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 6, Bild 1 von 2 Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Use the plastic opening tool to remove the glue from the speaker.
  7. Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 7, Bild 1 von 2 Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Loosen the speaker from the remaining glue with a plastic opening tool.
    • Insert the plastic opening tool into the rail that holds the speaker and push down.
  8. Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 8, Bild 1 von 2 Sony Dream Machine ICF-C180 Speaker Replacement: Schritt 8, Bild 2 von 2
    • Pull the speaker upward to remove it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Caleb John
101 Reputation
1 Anleitung geschrieben
Ein Kommentar
HEY! that's moderately adequate...
Caleb John - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 510
