Einleitung
This guide will show you how to dissemble a Sony ECM-MS907 microphone. This guide will help you if you believe any of the pieces apart of your microphone are broken or dirty that need to be replaced or cleaned.
For names of the microphone parts, please click the link below:
For signs that your microphone is broken, please click the link below:
Was du brauchst
Using the Phillips #00 screwdriver, remove the screw securing diaphragm to the base of the microphone.
Unscrew the base of the microphone in a clockwise motion and separate the bottom and top of the microphone.
Use a Phillips #0 screwdriver to remove the black screw near the bottom of the microphone.
Use the heavy duty spudger to detach the grip area from the microphone.
