Einleitung
In these instructions you will learn how to replace the joystick in a Sony Ericsson K750i
Was du brauchst
Remove the battery cover.
Press down firmly with your thumb and slide the cover back.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
Gently pry open the front casing by working an opening tool along the entire seam.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
That is the joystick head and it can be removed without taking anything apart. The problem is in joystick underneath it, which is soldered and need to be replaced. I know this phone is 15 years old, I just found mine and it brought back some memories :)
