Einleitung
This guide will assist you in removing the screen from your Sony Ericsson T68i.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the battery from the back. Remove the battery from the back.
    • Remove the battery from the back.
  2. Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  6. Remove the circuit board and screen from the device. Use your T6 to remove the 4 screws. Use your T6 to remove the 4 screws.
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  7. Remove the board and screen. Remove the board and screen. Remove the board and screen.
    • Remove the board and screen.
  8. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board.
    • Carefully remove the plastic clips holding the screen on the board.
Abschluss
Tim Dascomb
123 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 26-34, Regan Spring 2010 Mitglied von Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Mitglieder
13 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,572
