Einleitung
This guide will assist you in removing the screen from your Sony Ericsson T68i.
Was du brauchst
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws.
Fast fertig!
Abschluss
