Zum Hauptinhalt wechseln
Sony Ericsson T68i Speaker Replacement
Was du brauchst
  1. Sony Ericsson T68i Speaker Replacement, Keypad: Schritt 1, Bild 1 von 2 Sony Ericsson T68i Speaker Replacement, Keypad: Schritt 1, Bild 2 von 2
    • Remove the battery from the back.
  2. Sony Ericsson T68i Speaker Replacement: Schritt 2, Bild 1 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 2, Bild 2 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 2, Bild 3 von 3
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Sony Ericsson T68i Speaker Replacement: Schritt 3, Bild 1 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 3, Bild 2 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 3, Bild 3 von 3
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Sony Ericsson T68i Speaker Replacement: Schritt 4, Bild 1 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 4, Bild 2 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 4, Bild 3 von 3
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Sony Ericsson T68i Speaker Replacement, Screen: Schritt 5, Bild 1 von 3 Sony Ericsson T68i Speaker Replacement, Screen: Schritt 5, Bild 2 von 3 Sony Ericsson T68i Speaker Replacement, Screen: Schritt 5, Bild 3 von 3
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  6. Sony Ericsson T68i Speaker Replacement: Schritt 6, Bild 1 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 6, Bild 2 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove the board and screen.
  7. Sony Ericsson T68i Speaker Replacement: Schritt 7, Bild 1 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 7, Bild 2 von 3 Sony Ericsson T68i Speaker Replacement: Schritt 7, Bild 3 von 3
    • Carefully remove the plastic clips holding the screen on the board.
  8. Sony Ericsson T68i Speaker Replacement, Speaker: Schritt 8, Bild 1 von 3 Sony Ericsson T68i Speaker Replacement, Speaker: Schritt 8, Bild 2 von 3 Sony Ericsson T68i Speaker Replacement, Speaker: Schritt 8, Bild 3 von 3
    • Gently pry it out the speaker located in the screen housing with a small screwdriver or similar tool.
Abschluss
Tim Dascomb
159 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 26-34, Regan Spring 2010 Mitglied von Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 2,233
