Zum Hauptinhalt wechseln
Sony Ericsson TM506 Motherboard Replacement
Was du brauchst
  1. Sony Ericsson TM506 Motherboard Replacement, Battery Cover: Schritt 1, Bild 1 von 3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: Schritt 1, Bild 2 von 3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: Schritt 1, Bild 3 von 3
    • Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Push down with your thumb until the battery cover comes off.
  2. Sony Ericsson TM506 Motherboard Replacement, Back Case: Schritt 2, Bild 1 von 3 Sony Ericsson TM506 Motherboard Replacement, Back Case: Schritt 2, Bild 2 von 3 Sony Ericsson TM506 Motherboard Replacement, Back Case: Schritt 2, Bild 3 von 3
    • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
  3. Sony Ericsson TM506 Motherboard Replacement: Schritt 3, Bild 1 von 2 Sony Ericsson TM506 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the two rubber casings for the top two screws with a plastic opening tool.
  4. Sony Ericsson TM506 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson TM506 Motherboard Replacement: Schritt 5, Bild 1 von 3 Sony Ericsson TM506 Motherboard Replacement: Schritt 5, Bild 2 von 3 Sony Ericsson TM506 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
  6. Sony Ericsson TM506 Motherboard Replacement, Sound Box: Schritt 6, Bild 1 von 3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: Schritt 6, Bild 2 von 3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: Schritt 6, Bild 3 von 3
    • The sound box is attached to the case by two snap hooks.
    • Lift the sound box up to remove it from the case.
  7. Sony Ericsson TM506 Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 Sony Ericsson TM506 Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Locate the 80-pin connector.
    • Carefully, lift up on the connector to separate it from the board.
  8. Sony Ericsson TM506 Motherboard Replacement: Schritt 8, Bild 1 von 3 Sony Ericsson TM506 Motherboard Replacement: Schritt 8, Bild 2 von 3 Sony Ericsson TM506 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • There are two snap hooks that attach the motherboard to the case.
    • Using a plastic opening tool, carefully lift up on the motherboard to detach it.
    • The motherboard is extremely fragile. Try to be forceful yet delicate in the removal because it will not come off easily.
Abschluss
Daniel
83 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 1-1, Regan SU 2012 Mitglied von Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 1,160
