Einleitung
This guide provides instruction for installing a sound box for the Sony Ericsson TM506 cell phone.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Firmly hold the phone between your fingers with your thumb on the battery cover.
    • Push down with your thumb until the battery cover comes off.
  2. Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
    • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
    • Remove the two rubber casings for the top two screws with a plastic opening tool.
    • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
    • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
    • The sound box is attached to the case by two snap hooks.
    • Lift the sound box up to remove it from the case.
Abschluss
Daniel
Mitglied seit 20.06.2012
71 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 1-1, Regan SU 2012 Mitglied von Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Mitglieder
16 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 645
