Einleitung
Replacing the case is fairly easy, there will be small parts you will be removing so make sure you have a place to put them for safe-keeping.
  1. Slide the battery cover up and off the phone. Slide the battery cover up and off the phone.
    • Slide the battery cover up and off the phone.
  2. Pop the battery out of its slot by lifting it up. Pop the battery out of its slot by lifting it up.
    • Pop the battery out of its slot by lifting it up.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Insert the plastic opening tool in between the front case and the back case. Apply downward pressure to make the case lift upwards, thus popping the front case off. Use caution when removing the front case. It may seem stuck but just ease it out.
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
      • Use caution when removing the front case. It may seem stuck but just ease it out.
  5. Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver. Note that the top 2 screws are silver and the bottom 2 screws are black.
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
      • Note that the top 2 screws are silver and the bottom 2 screws are black.
  6. There is a black tab in the top left corner holding the core in place. Remove the core by pulling straight up to prevent breaking the tab. Remove the core by pulling straight up to prevent breaking the tab.
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  7. Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone. Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover. Remove the white plastic cover.
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
      • Remove the white plastic cover.
Abschluss
To reassemble your device, put removed pieces into the new back casing, then follow the steps in reverse order.
Emily Prescott
461 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-10, Forte Winter 2011 Mitglied von Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Mitglieder
16 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 3,403
