Einleitung
Removing the front case is easy, just be careful when you take it off.
Was du brauchst
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
To reassemble your device, follow these instructions in reverse.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
