Zum Hauptinhalt wechseln
Sony Ericsson W300i Camera Replacement
Was du brauchst
  1. Sony Ericsson W300i Camera  Replacement, Camera: Schritt 1, Bild 1 von 2 Sony Ericsson W300i Camera  Replacement, Camera: Schritt 1, Bild 2 von 2
    • The tools you will need for this step is the prying tool and the T6 Torx screwdriver.
  2. Sony Ericsson W300i Camera  Replacement: Schritt 2, Bild 1 von 3 Sony Ericsson W300i Camera  Replacement: Schritt 2, Bild 2 von 3 Sony Ericsson W300i Camera  Replacement: Schritt 2, Bild 3 von 3
    • Remove the back cover of the phone by pushing downwards with your thumbs.
  3. Sony Ericsson W300i Camera  Replacement: Schritt 3, Bild 1 von 2 Sony Ericsson W300i Camera  Replacement: Schritt 3, Bild 2 von 2
    • Now, remove the battery from the phone by gently prying the battery out.
  4. Sony Ericsson W300i Camera  Replacement: Schritt 4, Bild 1 von 2 Sony Ericsson W300i Camera  Replacement: Schritt 4, Bild 2 von 2
    • Remove the front plate from the phone by using the prying tool.
  5. Sony Ericsson W300i Camera  Replacement: Schritt 5, Bild 1 von 2 Sony Ericsson W300i Camera  Replacement: Schritt 5, Bild 2 von 2
    • You now have access to the fours screws that hold the front of the phone together. Remove the four screws.
  6. Sony Ericsson W300i Camera  Replacement: Schritt 6, Bild 1 von 2 Sony Ericsson W300i Camera  Replacement: Schritt 6, Bild 2 von 2
    • Use the prying tool to separate the two parts of the top of the phone
  7. Sony Ericsson W300i Camera  Replacement: Schritt 7, Bild 1 von 3 Sony Ericsson W300i Camera  Replacement: Schritt 7, Bild 2 von 3 Sony Ericsson W300i Camera  Replacement: Schritt 7, Bild 3 von 3
    • Use your fingers to remove the screen and unplug the ribbon cable from the bottom right corner of the back of the screen.
  8. Sony Ericsson W300i Camera  Replacement: Schritt 8, Bild 1 von 2 Sony Ericsson W300i Camera  Replacement: Schritt 8, Bild 2 von 2
    • Now you have access to the camera, which is the silver plate at the bottom of the phone. Remove the camera and replace with a new camera.
Abschluss
Laura Inbody
7 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-2, Garvin Spring 2016 Mitglied von Ohio State, Team 1-2, Garvin Spring 2016
OSU-GARVIN-S16S1G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 364
