Was du brauchst
The tools you will need for this step is the prying tool and the T6 Torx screwdriver.
You now have access to the fours screws that hold the front of the phone together. Remove the four screws.
Use your fingers to remove the screen and unplug the ribbon cable from the bottom right corner of the back of the screen.
Now you have access to the camera, which is the silver plate at the bottom of the phone. Remove the camera and replace with a new camera.
