Zum Hauptinhalt wechseln
Sony Ericsson W350a Memory Card Replacement
Was du brauchst
  1. Sony Ericsson W350a Memory Card Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Ericsson W350a Memory Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a Memory Card Replacement: Schritt 2, Bild 1 von 3 Sony Ericsson W350a Memory Card Replacement: Schritt 2, Bild 2 von 3 Sony Ericsson W350a Memory Card Replacement: Schritt 2, Bild 3 von 3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a Memory Card Replacement, Memory Card: Schritt 3, Bild 1 von 1
    • After removing the battery, insert the memory card into the lower left slot as designated by the circle in the picture. Be sure to have the contacts aligned into their appropriate slots.
Abschluss
Clemson, Team 1-4, Benson Spring 2012 Mitglied von Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,184
