Zum Hauptinhalt wechseln
Sony Ericsson W350a Speaker Replacement
Was du brauchst
  1. Sony Ericsson W350a Speaker Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Ericsson W350a Speaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a Speaker Replacement: Schritt 2, Bild 1 von 3 Sony Ericsson W350a Speaker Replacement: Schritt 2, Bild 2 von 3 Sony Ericsson W350a Speaker Replacement: Schritt 2, Bild 3 von 3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a Speaker Replacement, Speaker: Schritt 3, Bild 1 von 2 Sony Ericsson W350a Speaker Replacement, Speaker: Schritt 3, Bild 2 von 2
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  4. Sony Ericsson W350a Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
  5. Sony Ericsson W350a Speaker Replacement: Schritt 5, Bild 1 von 1
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  6. Sony Ericsson W350a Speaker Replacement: Schritt 6, Bild 1 von 1
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
  7. Sony Ericsson W350a Speaker Replacement: Schritt 7, Bild 1 von 2 Sony Ericsson W350a Speaker Replacement: Schritt 7, Bild 2 von 2
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
  8. Sony Ericsson W350a Speaker Replacement: Schritt 8, Bild 1 von 2 Sony Ericsson W350a Speaker Replacement: Schritt 8, Bild 2 von 2
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ldellos
112 Reputation
3 Anleitungen geschrieben
Clemson, Team 1-4, Benson Spring 2012 Mitglied von Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,032
