Zum Hauptinhalt wechseln
Sony Ericsson W518a Camera Lens Replacement
Was du brauchst
  1. Sony Ericsson W518a Camera Lens Replacement, Faceplate: Schritt 1, Bild 1 von 1
    • Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
  2. Sony Ericsson W518a Camera Lens Replacement: Schritt 2, Bild 1 von 3 Sony Ericsson W518a Camera Lens Replacement: Schritt 2, Bild 2 von 3 Sony Ericsson W518a Camera Lens Replacement: Schritt 2, Bild 3 von 3
    • Insert your plastic opening tool into the notch.
    • Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
    • When enough of the faceplate has been lifted it can be easily removed.
    • In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
  3. Sony Ericsson W518a Camera Lens Replacement, Camera Lens: Schritt 3, Bild 1 von 1
    • Remove the four 2mm Phillips screws from the back housing of the phone.
  4. Sony Ericsson W518a Camera Lens Replacement: Schritt 4, Bild 1 von 3 Sony Ericsson W518a Camera Lens Replacement: Schritt 4, Bild 2 von 3 Sony Ericsson W518a Camera Lens Replacement: Schritt 4, Bild 3 von 3
    • Insert the plastic opening tool in the notch at the top corner of the phone.
    • Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
  5. Sony Ericsson W518a Camera Lens Replacement: Schritt 5, Bild 1 von 2 Sony Ericsson W518a Camera Lens Replacement: Schritt 5, Bild 2 von 2
    • Remove the lends by pushing the lens from the inside of the housing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
kgkramer
121 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 1-5, Regan SU 2012 Mitglied von Cal Poly, Team 1-5, Regan SU 2012
CPSU-REGAN-SU12S1G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 1,134
