Einleitung
Use this guide to help you replace the LCD.
Was du brauchst
Insert the edge of an opening tool between the front cover and the phone.
Gently pry off the front cover working your way around the edges.
Insert a spudger between the lower edge of the screen and the phone.
Pry the screen up to disconnect the tabs on each side holding the screen in.
Use a spudger to remove the ribbon cable from the motherboard.
Lift the screen away from the phone
6 weitere Personen haben diese Anleitung absolviert.
