Zum Hauptinhalt wechseln
Sony Ericsson W810I Camera Lens Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Sony Ericsson W810I Camera Lens Replacement, Camera Lens: Schritt 1, Bild 1 von 1
    • Ensure the phone is switched off. Then press down firmly against the Cingular icon with your thumb.
    • Slide the panel down and remove the latch
  2. Sony Ericsson W810I Camera Lens Replacement: Schritt 2, Bild 1 von 2 Sony Ericsson W810I Camera Lens Replacement: Schritt 2, Bild 2 von 2
    • Lift the battery with your fingers and pull it out of the casing.
    • Remove the SIM card as well if you have one
  3. Sony Ericsson W810I Camera Lens Replacement: Schritt 3, Bild 1 von 1
    • Remove the two outer screws using a T7 Torx screwdriver.
  4. Sony Ericsson W810I Camera Lens Replacement: Schritt 4, Bild 1 von 1
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver.
  5. Sony Ericsson W810I Camera Lens Replacement: Schritt 5, Bild 1 von 2 Sony Ericsson W810I Camera Lens Replacement: Schritt 5, Bild 2 von 2
    • Remove the back faceplate on the camera side with the blue hand wedge.
  6. Sony Ericsson W810I Camera Lens Replacement: Schritt 6, Bild 1 von 3 Sony Ericsson W810I Camera Lens Replacement: Schritt 6, Bild 2 von 3 Sony Ericsson W810I Camera Lens Replacement: Schritt 6, Bild 3 von 3
    • Flip the phone over and pry off the front faceplate using multiple blue hand-wedges.
    • Separate the keypad from the logic board by turning it upside down and allowing it to fall into your hand.
  7. Sony Ericsson W810I Camera Lens Replacement: Schritt 7, Bild 1 von 1
    • Remove the two remaining screws at the top corners of the phone.
  8. Sony Ericsson W810I Camera Lens Replacement: Schritt 8, Bild 1 von 1
    • Remove the logic board with multiple blue hand-wedges. Prise the logic board away carefully to avoid damaging it or snapping the wiring.
  9. Sony Ericsson W810I Camera Lens Replacement: Schritt 9, Bild 1 von 1
    • From the inside of the panel, press down on the camera lens to pop it out of its mounting.
    • Replace the lens and reverse the process to reassemble the device.
Abschluss
Ben Micucci
186 Reputation
5 Anleitungen geschrieben
James Madison, Team 2-2, Allen Fall 2011 Mitglied von James Madison, Team 2-2, Allen Fall 2011
JMU-ALLEN-F11S2G2
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,412
