Einleitung
This guide will show the user how to replace the Camera Lens
Was du brauchst
Ensure the phone is switched off. Then press down firmly against the Cingular icon with your thumb.
Slide the panel down and remove the latch
Lift the battery with your fingers and pull it out of the casing.
Remove the SIM card as well if you have one
Flip the phone over and pry off the front faceplate using multiple blue hand-wedges.
Separate the keypad from the logic board by turning it upside down and allowing it to fall into your hand.
Remove the logic board with multiple blue hand-wedges. Prise the logic board away carefully to avoid damaging it or snapping the wiring.
From the inside of the panel, press down on the camera lens to pop it out of its mounting.
Replace the lens and reverse the process to reassemble the device.
