Einleitung
This guide will show the user how to remove the W810i Logic Board
Was du brauchst
Make sure the phone is off and press down firmly against the Cingular icon with your thumb
Slide the panel down and remove latch
Flip the phone over and pry off the front (keypad side) faceplate with multiple blue hand-wedges
Separate keypad from logic board by turning it upside down and allowing it to fall off
Remove the two remaining screws in the top corners of the phone using a T-6 screwdriver head
Remove the logic board with multiple blue hand-wedges, be careful not to snap the logic board in half, along with snapping the wiring from the logic board
2 weitere Personen haben diese Anleitung absolviert.
