Zum Hauptinhalt wechseln
Sony Ericsson Xperia Play LCD Display Replacement
Was du brauchst
Einführungsvideo
  1. Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: Schritt 1, Bild 1 von 3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: Schritt 1, Bild 2 von 3 Sony Ericsson Xperia Play LCD Display Replacement, LCD Display: Schritt 1, Bild 3 von 3
    • Remove the battery cover and the battery.
    • You have the 6x silver screws and 7x black screws and you can remove the rear bezel.
  2. Sony Ericsson Xperia Play LCD Display Replacement: Schritt 2, Bild 1 von 3 Sony Ericsson Xperia Play LCD Display Replacement: Schritt 2, Bild 2 von 3 Sony Ericsson Xperia Play LCD Display Replacement: Schritt 2, Bild 3 von 3
    • By using a plastic tool, disconnect the main flex cable connector. Be careful, near to the connector there are many small elements.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play LCD Display Replacement: Schritt 3, Bild 1 von 2 Sony Ericsson Xperia Play LCD Display Replacement: Schritt 3, Bild 2 von 2
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play LCD Display Replacement: Schritt 4, Bild 1 von 3 Sony Ericsson Xperia Play LCD Display Replacement: Schritt 4, Bild 2 von 3 Sony Ericsson Xperia Play LCD Display Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the 4x black screws.
    • Remove the black sticker on the corner and disconnect the touchscreen flex cable.
    • Disassemble front bezel.
  5. Sony Ericsson Xperia Play LCD Display Replacement: Schritt 5, Bild 1 von 3 Sony Ericsson Xperia Play LCD Display Replacement: Schritt 5, Bild 2 von 3 Sony Ericsson Xperia Play LCD Display Replacement: Schritt 5, Bild 3 von 3
    • Use the thin side of a plastic tool to separate the LCD display from the base bezel.
    • Now you are ready to install the new spare part.
    • I prefer to test the new spare part before the full assembly.
  6. Sony Ericsson Xperia Play LCD Display Replacement: Schritt 6, Bild 1 von 1
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
ZFix
196.863 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
333 Mitglieder
1.477 Anleitungen geschrieben
1 Kommentar zur Anleitung
Do you have a datasheet for the display? I wanted to reuse it but i cannot find the function of the pins.
jp r - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 27
Letzte 30 Tage: 56
Insgesamt: 5,966
