Zum Hauptinhalt wechseln
Sony Ericsson Xperia Play Rear Facing Camera Replacement
Was du brauchst
  1. Sony Ericsson Xperia Play Rear Facing Camera Replacement, Rear Facing Camera: Schritt 1, Bild 1 von 1
    • Follow the Prerequisite Guide on how to Remove the Controller Plate/Buttons to prepare the phone for disassembly. Stop when the motherboard has been detached.
    • Orientate the motherboard so that the camera faces away, as shown in the picture.
  2. Sony Ericsson Xperia Play Rear Facing Camera Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • With the camera facing away, pull it from the motherboard until it stands perpendicular to the board. Tweezers can be used to do this.
  3. Sony Ericsson Xperia Play Rear Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Use tweezers to pull the camera off of the motherboard. Hold on to the plastic connector and apply the force away from the board.
  4. Sony Ericsson Xperia Play Rear Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • The camera is now detached.
Abschluss
UMass Dartmouth, Team 7-3, Cichon Spring 2015 Mitglied von UMass Dartmouth, Team 7-3, Cichon Spring 2015
UMASSD-CICHON-S15S7G3
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 23
Insgesamt: 1,081
