Einleitung
If you touchscreen / digitizer is broken or not working, with this manual we will show you how to replace it.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Einführungsvideo
Remove the battery cover and the battery.
Unscrew the 7x black screws and 6x silver screws.
Remove the rear bezel.
after removing the 2x black philips screws, use a plastic tool to disconnect the main flex cable connector.
Disconnect the gaming keyboard flex cable.
Remove the 4x philips screws and the small black sticker on the corner.
Disconnect the touchscreen flex cable connector.
Disassemble the front bezel.
To separate the touchscreen from the base bezel use hot air and plastic tools.
