Zum Hauptinhalt wechseln
Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement
Was du brauchst
Einführungsvideo
  1. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: Schritt 1, Bild 1 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: Schritt 1, Bild 2 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: Schritt 1, Bild 3 von 3
    • Remove the battery cover and the battery.
    • Unscrew the 7x black screws and 6x silver screws.
    • Remove the rear bezel.
  2. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 2, Bild 1 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 2, Bild 2 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 2, Bild 3 von 3
    • after removing the 2x black philips screws, use a plastic tool to disconnect the main flex cable connector.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 3, Bild 1 von 2 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 3, Bild 2 von 2
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 4, Bild 1 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 4, Bild 2 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 4, Bild 3 von 3
    • Remove the 4x philips screws and the small black sticker on the corner.
    • Disconnect the touchscreen flex cable connector.
    • Disassemble the front bezel.
  5. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 5, Bild 1 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 5, Bild 2 von 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 5, Bild 3 von 3
    • To separate the touchscreen from the base bezel use hot air and plastic tools.
  6. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 6, Bild 1 von 2 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 6, Bild 2 von 2
    • Use double side adhesive tape to assemble the touch screen.
  7. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: Schritt 7, Bild 1 von 1
Abschluss
ZFix
196.863 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
333 Mitglieder
1.477 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 15
Letzte 30 Tage: 30
Insgesamt: 3,679
