Zum Hauptinhalt wechseln
Sony Ericsson Xperia Pro MK16A Power Button Replacement
Was du brauchst
    1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: Schritt 1, Bild 1 von 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: Schritt 1, Bild 2 von 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: Schritt 1, Bild 3 von 3
      • Use a plastic opening tool to get the back cover off your phone.
      • The plastic opener will work on any side, but be careful and pry gently.
      Frag FixBot
      Kommentar hinzufügen
    2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Removing the Battery: Schritt 2, Bild 1 von 1
      • Locate the battery in your phone.
      • Find the divot below the battery.
      • Use your thumb to lift the battery out of the phone.
      Frag FixBot
    1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: Schritt 3, Bild 1 von 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: Schritt 3, Bild 2 von 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: Schritt 3, Bild 3 von 3
      • Remove the 4 black screws with the Phillips screwdriver.
      • Remove the 4 silver screws with the Torx screwdriver.
      Frag FixBot
    2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Back Case: Schritt 4, Bild 1 von 1
      • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
      Frag FixBot
    3. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: Schritt 5, Bild 1 von 2 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: Schritt 5, Bild 2 von 2
      • When the inner back cover is off, locate and remove the power button.
      Frag FixBot
Abschluss
UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014 Mitglied von UMass Dartmouth, Team 6-5, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G5
3 Mitglieder
48 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,020
