Einleitung
Use this guide to replace a defective Logic Board.
Was du brauchst
Einführungsvideo
Switch-off the phone.
Remove the battery.
Unscrew 8x T6 Torx screws.
Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
Remove the Volume Up/Down and Camera buttons.
Unhook the SIM & SD Card reader unit and disconnect the flex cable.
Remove the Audio jack connector.
Disconnect 4x flex cables:
LCD Display
Menu buttons
Touchscreen
Earpiece, Volume & Power On buttons
