Zum Hauptinhalt wechseln
Sony Ericsson Z500a Keypad Replacement
Was du brauchst
  1. Sony Ericsson Z500a Keypad Replacement, Keypad: Schritt 1, Bild 1 von 3 Sony Ericsson Z500a Keypad Replacement, Keypad: Schritt 1, Bild 2 von 3 Sony Ericsson Z500a Keypad Replacement, Keypad: Schritt 1, Bild 3 von 3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Keypad Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Keypad Replacement: Schritt 3, Bild 1 von 1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
Abschluss
Cal Poly, Team 7-12, Maness Spring 2010 Mitglied von Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 2,734
